Old 04-13-2015, 12:07 PM   #265 (permalink)
firehawk618
97 Civic HX sedan VX trans - '98 Honda Civic LX + HX + VX
90 day: 41.9 mpg (US)
Funny, aluminum is supposed to be lighter! It must be far thicker, as I suggested elsewhere. How much of a difference does three pounds make?
They are also supposed to dissipate heat faster.
The Al pan is rated 36 lb-ft and steel is forty, which is pretty close to me.
Put a Quikvalve on it the first time you change the oil and you should never worry about it again!
Personally will never go back to the steel one. Gaskets always seem to spew or seep oil for some reason on that one.
1998 LX with a full HX swap + VX transaxle.
