Old 04-13-2015, 04:02 PM   #25 (permalink)
miscrms
On the other end, I've seen the 2011-12 motor only weight put at ~130 lbs, and the 2013+ motor plus reduction gear put at ~160lbs. For inverters I've seen 37lbs for 2011-12, and 33 lbs for 2013+. Charger ~60lbs for 2013+, haven't found a weight for 2011-12 but should less as 3.3kW vs. 6.6kW.
Hope that helps,
Rob
