If you're getting a lean stumble around half throttle I think I'd bring the needle back up a step, and then re evaluate. Might then be able to drop the main down a size or 2. Did you move the needle before the exhaust mod? If so, maybe now returning to stock jetting with the exhaust mod, would leave you running as lean as dropping the needle before the exhaust work
