I hope that resolved your transmission issues. You may want to check that your ac condenser, radiator, intercooler, (anything in the front air is supposed to flow through) is not clogged or stopped up causing the transmission to overheat due to inadequate flow through the cooler. I now know that was the reason I had many many transmission issues in my 91 Chevy K2500.
