Old 04-14-2015, 08:27 PM   #3 (permalink)
101Volts
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 18.73 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
Originally Posted by darcane View Post
Do you have rear disc brakes? That vintage Silverado had a lot of trouble with the e-brakes sticking and debris getting in the calipers and causing odd wear, so much so that they eventually switched back to drum brakes. I assume the Burb would have the same problems if you had the rear disc brakes.
I have no idea, yet.
I tried to get the car moving and as it turned out, if I pulled the release lever up and pulled the pedal back up it came unlocked. But, now the E-Brake doesn't hold so I need that worked on.
