Old 04-15-2015, 12:51 PM   #48 (permalink)
oil pan 4
An easy way to charge the battery with out lifting the hood is to put a repurposed trailer wire connector at the front or back of the car wired into the battery. Then have the corresponding connector on your battery charger.
I use my suburbans 7 pin RV connector for this since it already has a 12 volt power source for charging a trailers emergency break away braking battery. Its wired straight to the battery with 8ga wire and a 35 amp fuse. I have an RV plug battery charger attachment with the ground and 12 volt source hooked up. It back feeds battery charging power through that circuit to the vehicle battery.
Most of the time when I start the suburban it doesn't leave the yard. It gets started to move it, hook or unhook from a trailer and I am not going to leave it running just to charge the battery.
