Old 04-15-2015, 10:07 PM   #6 (permalink)
user removed
Oh I almost forgot. make sure to lube the pivot ball where it mates with the release fork (5th attached photo). It may even be worth it to replace the pivot ball if there is any indication of it lacking lube. I have seen the pivot ball break off from lack of lube and seen the mating point of the release fork with a hole worn through it from the pivot ball. Looks like what you have had been lubed so you should be ok. Lightly lube where the throughout bearing rides on the collar and a small blob where the imput shaft goes into the back of the crankshaft, but not too much in either place so it won't get on the clutch disc and cause chatter.
regards
mech
