Old 04-16-2015, 04:06 PM   #1586 (permalink)
aerohead
think
*Forward plunging roofline is helpful.
*Along with sunshade,it helps keep the rooftop in a beneficial pressure gradient.
*Being 'chopped' reduces frontal area,as mentioned already.Good.
*The radiator cap,it's excrescence,spare tires,4-mirrors,upright windscreen and A-pillars are going to compromise the side flow along the greenhouse.
*If the flow is intact longer along the top due to the taper it won't see the full benefit because the side turbulence and it's low pressure which may cause downward bleeding and vorticity.
*It IS and abomination.Highly mutilated!
BamZipPow (04-16-2015)
