Originally Posted by MPaulHolmes
Zero is actually about 2.5v, since the throttle was configured as a wig wag. But I don't know what the state of the code is on the instructable. It may still be filler that I was going to get to.
Um .. I should have remembered that ...
And if I didn't remember it, I should have looked in the code.
I'm not using the code from the instructable, I'm still running the code that you/we loaded at your place. But I can't build it
