Old 04-17-2015, 03:18 PM   #5 (permalink)
cosmick
Experienced UAW Mechanic
Your first concern for taller tires has to be what ha[[ens if you go over a bump while turning tight? Get it rubbing too much, with the entire frint weight of the car on the rub point, the tire will lock up, possibly causing a crash.
The best way to check is fit the proposed tire with the front springs removed entirely, but that's a lot of work and cost, tires can't be returned once mounted. That's why the WheelMate was invented.
