Old 04-18-2015, 02:22 AM   #7 (permalink)
bentring
Stream - '16 Volkswagen Jetta
90 day: 33.7 mpg (US)
Originally Posted by Old Tele man View Post
FWIW, in reality, the mathematical tyre diameter and rolling tyre diameter are NOT the same. The mathematical diameter does NOT account for vehicle weight-loading, which slightly flattens the tyre bottom, and thus slightly reduces the actual rolling diameter by about 3%. A good approximation is:
Dia(rolling) ≈ 0.97*Dia(math)
I never would have thought about that mattering, and I got curious so I did a 2 minute research session. According to Michelin :
The SAE procedure recognizes that within the test method itself there will be some variation. In fact, there are other factors that cause variation on Tire Revs./Miles among similar tires. Be aware that just because similar tires have the same overall diameter this does not necessarily mean that they will have the same Tire Revs./Mile. The SAE procedure determines the Tire Revs./Mile to within ± 1.5%. Some factors, which cause variation among tires, are: • Load and Pressure – A difference in Load/Pressure could alter the Tire Revs./Mile measurement by as much as 1.5%. If pressure is constant, going from an empty vehicle to a fully loaded vehicle can change the Tire Revs./Mile by 1 to 1.5%. • Treadwear – The Tire Revs./Mile varies from a new tire to a fully worn tire. This can affect Tire Revs./Mile by as much as 3% from the rated Tire Revs./Mile. • Tread Geometry – The height and stiffness of the blocks and the shape of the tread pattern can affect Tire Revs./Mile. • Torque – The presence of driving and braking torque can affect the Tire Revs./Mile. • Type and Condition of Pavement – Asphalt vs. concrete, wet vs. dry can create difference in Tire Revs./Mile.
