Battery charging
Just want to send an update. I hooked the grid charger to the connections from the linkk and have been able to charge the battery. The IMA light has been off and I was actually able to get the car through inspection!! I have been charging the battery about once a week overnight and have seen improvements on the packs charge and discharge rates. Thank you all for you help with this. I can actually use the car again. Wish I had done this sooner!!
