Old 04-19-2015, 03:41 PM   #4 (permalink)
freebeard
The ideal Template is half-circular in section, and diameter is 2x the radius. Maybe you can infer it from this:
I don't think they are. I'm pretty familiar with that body...
Trust me, I was there and took the picture. The rear edge was in line with the outside of the tire. It makes what aerohead calls a divergent nozzle (I compare to an exponential horn loudspeaker). The inside faces act to slow down the air under the body, raising it's pressure.
Nice but impractical unless your vehicle is suited to that design.
Originally Posted by aerocivic
Side skirts made of coroplast (there are 2 side skirts on each side, one even with the inner edge of the tires, the other even with the outer edge of the tires).
http://ecomodder.com/forum/showthread.php/aerocivic-how-drop-your-cd-0-31-0-a-290.html#post2111
You're probably right about the high-centering, but that's a long wheelbase. I've seen an 18-wheeler that ran aground and was immobilized on a railroad crossing.
The retractable trailer tail may be too much trouble. Here's a stepped box:
This could be mounted on the rear doors and hinge with them.
