Old 04-20-2015, 12:43 AM   #7 (permalink)
firehawk618
97 Civic HX sedan VX trans - '98 Honda Civic LX + HX + VX
90 day: 41.9 mpg (US)
Another thing is, you need to judge your true MPG's over tanks, not just a partial fill up or two.
The reason I say this is I also have a 98. I get pretty significant swings in calculated MPG's and I believe it's because the tank doesn't always allow the same amount of fuel to be pumped in. The only way to know for sure is track your tank/miles over time. Not just a 6 gallon fillup.
Probably the only way to get consistent full tanks is to trickle fill until gas is sitting at the top of the fill tube. I refuse to do this with a gasoline car because I don't want gas back filling my evap system and all that.
I would do the trickle filling regularly in my previous diesel vehicles.
With your car a scangauge OR ultragauge would be a great investment if you want to learn how to drive it better and maximize MPG's.
I recommend the Ultragauge for the following reasons:
1. It's much cheaper.
2. The display is much better.
3. You can display upto 8 parameters at once vs 4 on the Scangauge.
4. You get a selection of mounts with the Ultragauge for only a couple additional dollars.
Numbers two and three are all my personal opinions having owned both.
1998 LX with a full HX swap + VX transaxle.
The Following 2 Users Say Thank You to firehawk618 For This Useful Post:
DukeEcoNukem (06-04-2016), MobilOne (04-30-2015)
