Very Cool Idea, thanks BabyDiesel!!!
My car is a little... I mean a lot different.
First its a turbo AWD and anyone in their right mind would not try to make it a FE car.
Its also a automatic transmission. Another major FE problem.
I wanted to have a car that would perform at the track and run decent 1/4 mile times in the 9's at over a 130 mph. I also wanted to have a performance car that could still get great fuel mileage. So I started building the perfect beast. The AWD helps it run sub 1.3 second 0 to 60 mph. The turbo's give it the power to make over 650 WHP when needed. The Engine Management helps me tune all the ECU parameters at my finger tips, including Lean Burn for FE.
The biggest contribute to my FE is my home built Lean burn system. Its design is to be able to run over 30:1 A/F ratios without a miss-fire.
My Lean Burn system makes it possible to run with almost no throttle pumping losses by utilizing the turbo's.
Trying to keep it short so I will call it good. If anyone wants to see more on my car check out my build thread. Thanks again everyone for your builds and camaraderie.
1991 Talon TSi Compound Turbo AWD
Automatic 4 speed
Off road Lean-Burn 30:1+ A/F
2800 lbs with driver
650+ WHP
0 to 60 mph in 2.4 seconds
Current Mods: Engine:
2.0L
modified 1g turbo pistons, spray-guided crown
Ultra Lean Burn system.
modified head, spray-guided high heat direct port.
custom camshafts.
intake manifold, high heat direct port w/adjustable port angle injection.
Turbo System:
High-pressure Modified Blow-Down Turbine 13g internal gate dump to atm.
Low- pressure stock configuration FP Red BB, mid mount.
DNP Turbo exhaust manifold.
44mm Tial Bi-Pass waste gate.
FMIC 3" core.
LP Turbo pre-intercooler.
Tilton 40-527 external oil pump.
Jegs 12V Vacuum pump.
ECU:
ECM Link Engine Management system.
EGR:
HOT/COLD Electronic controlled cold EGR system.
Transmission:
Transtar/IPT 5 disk front clutch kit in stock basket, Transtar/IPT end clutches, double up stock flexplate, John Deere HyGard fluid, Foreign Muscle DSM (Transmission Control Unit), EPROM Upgrade full line pressure with pre-set rpm shift points.
2g lock-up converter.
Rear antenna and rear wiper removal.
Front bumper lower grill block.
No-Lift Braking:
Activates extreme lean burn secondary map and maintains positive intake pressure with no pumping losses.
Secondary Waste Solvent fuel system
Rota Grid Wheels 14.5 lbs
Hoosier QTP Tires
