A mechanic friend of mine on Facebook commented on what might be affecting the Teal car:
"PCV valve... vacuum hose disconnected... Cam timing 1 tooth off (IF the T-belt has been done)... weak/failing O2 sensor... weak/failing fuel injector(s)..."
Some of that sounds too expensive.
