Originally Posted by Xist
I took all of my pictures before taking apart anything. Right now, the battery, intake, and windshield washer reservoir are in the trunk.
I will put them back and get some dye. I am not feeling this is progress!
Thanks for responding, though. I was frustrated to deal with something so big, seemingly on my own.
If you are not 100% certain as to the source of the oil leak I would highly suggest to put it back together, clean it up and use the dye.
From the description of your leak it should be very easy to pinpoint the major loss source.
Wouldn't you be disappointed if you pulled the heads and put it all back together to discover it was the oil cooler spewing oil.....
