Old 04-22-2015, 12:00 AM   #16 (permalink)
oil pan 4
There are guys that have old GM 60s and 70s cars with big blocks and up dated drive line using over drive autos and better highway gears (3.30 to 3.55) are getting 15 to 18.
Emissions are a problem with the 440, why they went to the V-10 for big block torque because those huge cylinders don't burn well.
GM stayed with a V8 and made it bigger.
They went from the 7.4L to the 8.1.
I say try using a carb and tune it with a wide band oxygen meter.
Tune the primaries to run a little lean and run the secondaries as fuel dumps bring the A/F ratio down to between 12.5:1 to 13.2:1.
If you are going to drive cross country you don't want a bunch of proprietary fuel injection system parts that cant be found at any auto parts store.
