Originally Posted by BabyDiesel
I would like to offer my car as an experimental platform!
There are several places nearby me with 87, 90, & 93 E0 gasoline. I can do a three tank trial run with 87 E0 if y'all would like. I have been running 89 E10 for the past 5 tanks at least. So yeah, I will gladly be a guinea pig
First, is your car set with standard "from the factory" settings? No playing allowed. Second, a year of testing with E0 & one year testing with E10 would be best. Failing that, we'll see what others determine as OK. Third, since the most cars are set to use standard 87 octane(& hopefully yours is, also), a comparison between 87 octane E0 & 87 octane 10% ethanol blends would be best. Are you using 89 octane E10, because you are having trouble with 87 octane E10? If you are having problems with 87 octane E10 with a car set to factory standard 87 octane gasoline, E0 has an increased chance of improving your engine performance compared to 87 octane E10.
