Old 07-25-2008, 06:43 PM   #74 (permalink)
pasadena_commut
On the stock Legacy there are two air intakes, the top one is above the bumper and includes the engine's air intake, and the second one is built into/below the bumper. In another thread you indicated that your upper grill is completely blocked off with tape. What about the lower one? Is it sealed off by the coroplast air dam, or is there still space between the dam and that opening for air to go through? If it is sealed, the radiator air is coming from where exactly? I guess it would have to be the gap between the bumper and the radiator.
Do you have a picture that shows how you relocated the engine's air intake?
Also, earlier in this thread you indicated that some of your mods were held in place by wood screws. Having had a tire failure caused by a screw picked up from the road before, I would urge you to find some other kind of fastener which is less hazardous to tires if it falls out. The one great thing about nylon fasteners is that, even though they do fall out sometimes, when they are run over they just squish and don't damage anybody's tires.
Thanks.
