Dreamer
I just tried a couple of builds to see what output i received.
I am using Linux not Windows so the output is a bit different but i didn't get any nag lines with XC16 whereas i do with a project using XC8?
Also the nag lines in XC8 are trying to be informative and helpful.
Maybe somebody using the Windows version of the compiler could check and see if their compiler output is similar to yours.
XC8 build
Code:
CLEAN SUCCESSFUL (total time: 55ms)
make -f nbproject/Makefile-XC8_PIC16F1827.mk SUBPROJECTS= .build-conf
make[1]: Entering directory '/home/jase/MPLABXProjects/BMSMaster_CRW_MPLABX_v1.3/BMSMaster.X'
make -f nbproject/Makefile-XC8_PIC16F1827.mk dist/XC8_PIC16F1827/production/BMSMaster.X.production.hex
make[2]: Entering directory '/home/jase/MPLABXProjects/BMSMaster_CRW_MPLABX_v1.3/BMSMaster.X'
"/opt/microchip/xc8/v1.21/bin/xc8" --pass1 --chip=16F1827 -Q -G --double=24 --float=24 --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/XC8_PIC16F1827/production/configuration_bits.p1 configuration_bits.c
"/opt/microchip/xc8/v1.21/bin/xc8" --pass1 --chip=16F1827 -Q -G --double=24 --float=24 --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/XC8_PIC16F1827/production/interrupts.p1 interrupts.c
"/opt/microchip/xc8/v1.21/bin/xc8" --pass1 --chip=16F1827 -Q -G --double=24 --float=24 --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/XC8_PIC16F1827/production/main.p1 main.c
"/opt/microchip/xc8/v1.21/bin/xc8" --pass1 --chip=16F1827 -Q -G --double=24 --float=24 --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/XC8_PIC16F1827/production/system.p1 system.c
"/opt/microchip/xc8/v1.21/bin/xc8" --pass1 --chip=16F1827 -Q -G --double=24 --float=24 --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/XC8_PIC16F1827/production/UARTPIC16.p1 UARTPIC16.c
"/opt/microchip/xc8/v1.21/bin/xc8" --pass1 --chip=16F1827 -Q -G --double=24 --float=24 --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/XC8_PIC16F1827/production/lcd_drv.p1 lcd_drv.c
"/opt/microchip/xc8/v1.21/bin/xc8" --pass1 --chip=16F1827 -Q -G --double=24 --float=24 --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/XC8_PIC16F1827/production/user.p1 user.c
"/opt/microchip/xc8/v1.21/bin/xc8" --chip=16F1827 -G -mdist/XC8_PIC16F1827/production/BMSMaster.X.production.map --double=24 --float=24 --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -odist/XC8_PIC16F1827/production/BMSMaster.X.production.elf build/XC8_PIC16F1827/production/configuration_bits.p1 build/XC8_PIC16F1827/production/interrupts.p1 build/XC8_PIC16F1827/production/main.p1 build/XC8_PIC16F1827/production/system.p1 build/XC8_PIC16F1827/production/UARTPIC16.p1 build/XC8_PIC16F1827/production/lcd_drv.p1 build/XC8_PIC16F1827/production/user.p1
:: warning: (1273) Omniscient Code Generation not available in Free mode
Memory Summary:
Program space used FB0h ( 4016) of 1000h words ( 98.0%)
Data space used EAh ( 234) of 180h bytes ( 60.9%)
EEPROM space used 0h ( 0) of 100h bytes ( 0.0%)
Configuration bits used 2h ( 2) of 2h words (100.0%)
ID Location space used 0h ( 0) of 4h bytes ( 0.0%)
Running this compiler in PRO mode, with Omniscient Code Generation enabled,
produces code which is typically 40% smaller than in Free mode.
The MPLAB XC8 PRO compiler output for this code could be 1555 words smaller.
See http://microchip.com for more information.
Microchip MPLAB XC8 C Compiler V1.21
Copyright (C) 2013 Microchip Technology Inc.
License type: Node Configuration
make[2]: Leaving directory '/home/jase/MPLABXProjects/BMSMaster_CRW_MPLABX_v1.3/BMSMaster.X'
make[1]: Leaving directory '/home/jase/MPLABXProjects/BMSMaster_CRW_MPLABX_v1.3/BMSMaster.X'
BUILD SUCCESSFUL (total time: 24s)
Loading code from /home/jase/MPLABXProjects/BMSMaster_CRW_MPLABX_v1.3/BMSMaster.X/dist/XC8_PIC16F1827/production/BMSMaster.X.production.hex...
Loading completed
XC16 build
Code:
CLEAN SUCCESSFUL (total time: 1s)
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory '/home/jase/MPLABXProjects/ACInductionController'
make -f nbproject/Makefile-default.mk dist/default/production/ACInductionController.production.hex
make[2]: Entering directory '/home/jase/MPLABXProjects/ACInductionController'
"/opt/microchip/xc16/v1.24/bin/xc16-gcc" ACInductionController.c -o build/default/production/ACInductionController.o -c -mcpu=30F4011 -MMD -MF "build/default/production/ACInductionController.o.d" -g -omf=elf -O0 -msmart-io=1 -Wall -msfr-warn=off
"/opt/microchip/xc16/v1.24/bin/xc16-gcc" UART4011.c -o build/default/production/UART4011.o -c -mcpu=30F4011 -MMD -MF "build/default/production/UART4011.o.d" -g -omf=elf -O0 -msmart-io=1 -Wall -msfr-warn=off
"/opt/microchip/xc16/v1.24/bin/xc16-gcc" -o dist/default/production/ACInductionController.production.elf build/default/production/ACInductionController.o build/default/production/UART4011.o -mcpu=30F4011 -omf=elf -Wl,,--defsym=__MPLAB_BUILD=1,,--script=p30F4011.gld,--stack=16,--check-sections,--data-init,--pack-data,--handles,--isr,--no-gc-sections,--fill-upper=0,--stackguard=16,--no-force-link,--smart-io,-Map="dist/default/production/ACInductionController.production.map",--report-mem
Program Memory [Origin = 0x100, Length = 0x7f00]
section address length (PC units) length (bytes) (dec)
.text 0x100 0x170 0x228 (552)
.const 0x270 0xff0 0x17e8 (6120)
.text 0x1260 0x1a60 0x2790 (10128)
.dinit 0x2cc0 0x174 0x22e (558)
Total program memory used (bytes): 0x43ce (17358) 35%
Data Memory [Origin = 0x800, Length = 0x800]
section address alignment gaps total length (dec)
.ndata 0x800 0 0x1ac (428)
.nbss 0x9ac 0 0x188 (392)
.ndata 0xb34 0 0x58 (88)
.nbss 0xb8c 0 0x40 (64)
Total data memory used (bytes): 0x3cc (972) 47%
Dynamic Memory Usage
region address maximum length (dec)
heap 0 0 (0)
stack 0xbcc 0x434 (1076)
Maximum dynamic memory (bytes): 0x434 (1076)
"/opt/microchip/xc16/v1.24/bin"/xc16-bin2hex dist/default/production/ACInductionController.production.elf -a -omf=elf
make[2]: Leaving directory '/home/jase/MPLABXProjects/ACInductionController'
make[1]: Leaving directory '/home/jase/MPLABXProjects/ACInductionController'
BUILD SUCCESSFUL (total time: 16s)
Loading code from /home/jase/MPLABXProjects/ACInductionController/dist/default/production/ACInductionController.production.hex...
Loading completed
