Old 04-26-2015, 08:02 PM   #9 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Originally Posted by NateHale88 View Post
Curious tho what is the difference between going EOC and just shutting the car off after you are parked and done driving? I have noticed that if I am really getting on it a lot that the car has its own sort of turbo timer high speed fan cycle after I turn it off.
The main difference is if you P&G, it's high load followed by a shut down, that's bad news for the turbo. As a rule, as long as the engine is driven off boost for the last mile you're OK to shut it down. I'll sometimes do an EOC if for example I've just descended a nice long hill and I know the turbo has had a chance to cool.
Modern turbos are very good and some people routinely EOC them. Just keep what's been said above in mind if you do.
Some cars will run their radiator fans for a while after shut down if they're really hot. This isn't to do with the turbo more to prevent heat soak under the bonnet.
It's also possible to modify a turbo car for P&G EOC by fitting an external oil pump into the oil supply line.
