Old 04-27-2015, 06:49 AM   #57 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
Well, I ended up doing a bit more sanding and putting another coat of paint on the shell, looks a bit better now. I found and used flat black this time instead of gloss and thanks to that and the extra sanding I am happier with how this coat of paint turned out.
I also got the windows cut out and installed. See the attached pictures, which I am fairly sure I actually attached this time. Notice my high-tech window clamps holding the lexan against the adhesive.
Spent quite a while looking for my third brake light that fits into the opening in the camper shell, thought I had lost it. Turns out it was right where I thought it was at the very first place I looked for it, I just overlooked it the first time around. The joys of not being organized very well.
Anyway the windows adhesive should be set up today and I figured out the wire I need to tap into to get the brake light signal, so it looks like another day or two and I will have this project finished.
ID:	17450   Click image for larger version
The Following 2 Users Say Thank You to aardvarcus For This Useful Post:
aerohead (04-27-2015), BamZipPow (04-27-2015)
