Old 07-25-2008, 10:00 PM   #42 (permalink)
Andyman
amateur mech. engineer
Sporty Accord - '88 Honda Accord LX-i
90 day: 23.25 mpg (US)
Dad's Camry - '01 Toyota Camry CE
90 day: 22.81 mpg (US)
Artie's Camry - '98 Toyota Camry
90 day: 37.3 mpg (US)
lawnmower engine powering a bike trailer
Originally Posted by millenniumtree View Post
I've considered the idea of a powered trailer for a bicycle as well. It would just be a single-wheel with a small lawnmower or strimmer motor on top. People say you can't use a vertical-shaft motor for these types of things, but I say you just have to be more creative. :P
I've been thinking about this too. One solution I like is to connect the engine to an oil pump, use the oil flow to run a second oil pump used as a motor and transmit the power to the wheel with a chain or belt. Maybe the second pump could even be built into the hub of a wheel. If one of the the pumps is a variable displacement type, this would allow changes in gear ratio. I've seen a saw mill on a trailer that used this kind of power transmission.
