Alright, got my coolant leak fixed! Commuting with the car once again! Will be interesting to see the effect all the new parts has on file economy.
Total list done the past week
Timing belt/tensioners (old belt was craaacked! Tensioners were a little more stiff than new ones)
Water pump (Old one was slightly dragging compared to new)
Thermostat+housing (197° tstat, OEM specs)
Valve cover gasket (won't have an effect on FE)
So we will see if there's any difference. I doubt it but you never know.
