Originally Posted by California98Civic
Yes. Unless the voltage or load crosses other limits/thresholds. And climbing hills at low speeds the voltage will sit even lower. It also will maintain a low charge in some conditions. For example, just before climbing a slow hill from a stop, my voltage meter shows say 12.34. I key on, begin the climb, flip the alternator switch on, and the charge climbs and stays only at 12.5 volts during the whole climb.
I'm really impressed Honda were doing it all those years ago. Do you know how the alt is controlled? I wonder if it could be a simple retrofit for 'dumb' units. Based on my experience with 'smart' alts, there's a good 5% gain to be had with no drawbacks.
