Old 04-30-2015, 02:04 PM   #46 (permalink)
hamsterpower
one of thOOOse people
twitchy - '98 honda civic dx + sir + ls
90 day: 30.2 mpg (US)
Norman - '14 Ford E-350 EXT
90 day: 16.18 mpg (US)
Silver - '12 VW Golf Base
90 day: 26.1 mpg (US)
Sparta - '19 Honda CB300R
90 day: 84.07 mpg (US)
Originally Posted by MamaBear2015 View Post
Does anyone know if the Ultra Gauge measures timing too?
Is there a way to measure cam timing without removing the timing belt and all?
You don't remove the timing belt to CHECK the cam timing. You set cylinder 1 to top dead center and look at the marks on the cam pulley. You will need to remove the valve cover to do this. At TDC the "UP" lable points up and two other marks will be even with the top of the head. if both are angled the belt slipped.
The Following User Says Thank You to hamsterpower For This Useful Post:
MobilOne (04-30-2015)
