Old 04-30-2015, 07:28 PM   #16 (permalink)
freebeard
The template has a width twice it's height and tapers to a point. A square body gets two tapers to the top's one (plus the little help from the bottom). So the side tapers will meet at a vertical line.
One thing you could do would be flat plates as part of a box cavity that hinge on the same line as the doors. That line is probably 6-8" in from the side. The plates might be shorter or longer than the doors and the doors could open partially before they push open the aero add-ons. The top could stay fixed and the bottom rear bellypan could incorporate a step.
