Old 05-01-2015, 07:53 PM   #59 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
Finally got the half shell finished enough for now and installed on the truck. I had trouble with tying into the existing wiring from the brake lights, as I thought I could piggyback on the existing trailer light controller harness I installed, but after quite a bit of troubleshooting, I figured out the Tacoma uses a separate circuit to run the trailer brake controller light circuits. I assumed the aftermarket light controller was triggering off of the brake light and turn signal wires, but not so much. Anyway since my truck is a base model with no towing package, I did not have any of the fuses or relays installed from the factory, so basically the towing circuits didn’t work. Finally I traced the real tail lamp wire, and once I spliced into that everything worked fine.
As you can tell, the adhesive I used to hold the windows in looks horrible. It dries clear, but when you use a heavy coat it doesn’t dry very fast. I installed the windows Sunday, these pictures are from today and yes it is still not dry.
I have had the shell on the truck for two days now, I can tell a bit of a difference in coasting down hills. A couple hills I used to loose speed on as I rolled down I now don’t lose speed. I will refrain from making assumptions on differences in fuel consumption until I run a full tank through the truck.
ID:	17487   Click image for larger version
ID:	17488   Click image for larger version
ID:	17489   Click image for larger version
The Following 3 Users Say Thank You to aardvarcus For This Useful Post:
aerohead (05-02-2015), BamZipPow (05-02-2015), mikeyjd (05-06-2015)
