Old 05-02-2015, 12:41 PM   #51 (permalink)
MamaBear2015
Originally Posted by MobilOne View Post
You mentioned a grinding noise when you accelerate the sub-optimal Honda. Could it be a very mild spark knock? Cavitation in the torque converter? Dry axle cv joint? I'm trying to think of what could cause a grinding type sound when accelerating.
Sounds like it's inside the cylinders while firing, but not a ping like I've heard in the distant past with other cars.
Transmission slipping?
Between 2nd and 3rd gears, especially when going up hills and accelerating - the harder the acceleration, the more it happens. It's independent of the grinding.
Does the tach bump up when you hear the grinding?
No.
Do you drive with one foot touching the brake?
Nope, never have.
Does anything else occur when the grinding sound happens?
No.
When one accelerates, the engine torques backward (top of engine tries to move toward the firewall). Could this action be causing something to rub, such as a pulley?
No, this sounds internal, in the firing cylinders.
It might be worthwhile to check the engine mounts. Perhaps one was left loose when the camshaft belt was changed? You can tell; the grinding noise bothers me. Especially since no one else has addressed it.
I wonder if the timing is actually retarded? Could it do that?
Well, I've ordered a timing light ( couldn't find my old one ) and it should be here in a week.
