Old 05-03-2015, 08:20 PM   #1 (permalink)
mechcd
Carl Winslow - '02 Ford Crown Victoria Police Interceptor
90 day: 23.89 mpg (US)
Penelope - '99 Pontiac Grand Prix GTP
90 day: 31.96 mpg (US)
The Saabray - '84 Honda VF700S Sabre
90 day: 30.36 mpg (US)
The (Silver) Ghost - '99 Ford Crown Victoria Police Interceptor
90 day: 24.26 mpg (US)
Cool Hello! (Just a guy in a car)
Hello!
I've been lurking for a while and it's finally time for a real post. There is lots of great information on here and it's really neat to see what people come up with.
I have a V6 '99 Pontiac Grand Prix GTP and a V8 '02 Crown Victoria Police Interceptor.
The Grand Prix does much better than the 'vic out of the box, I was getting 27-30 mpg without really trying and everything stock. It has now been upgraded with headers, hi-flow catalytic converter, smaller (faster) supercharger pulley, and less restriction in the air box. These were mostly for performance but my mpg started to go up into the low 30s. I picked up a used ScanGauge II to monitor knock for the supercharger, but found it had quite a few other googies like fuel trims, gallons per hour of fuel use, and engine load. These have really helped me push the bar higher on efficiency. I have since blocked the upper grille and put weatherstripping around my cheapo-poorly-fitting headlight housings, 3/4 of the sides of the hood, and added brake drag clips to my brake pads. I have recently added wheel spats, but am not sure if they have done much or anything at all.
Future and likely to occur plans include blocking the lower grille, extending the height of the front air dam, and possibly finding a way to close up the huge cup shaped openings for the fog lights. I'd like to hit 40 mpg hwy or even just catch a flicker of 40 on the trip computer.
Possible future plans include finishing up what GM started with the front under pan. They did a pretty decent job covering up the big offenders, but there are still a few areas I'd like to divert air away from. I would like to lower it just a smidgen, but lowering springs are really expensive and I'm not sure if that affects the rest of the suspension in regards to having it aligned.
The Crown Vic..... was... a salvage car that I bought for the winter and ended up thoroughly enjoying. It rides nice, handles pretty well, and has some oomph if I need it. It's a bit of a basket case but it responds exceptionally well with just a little TLC. I also have another interceptor that I got at the same auction for spare parts. That one has a huge crack in the frame and will probably be stripped for parts.
The 'vic started off with a huge weight reduction by being a police car instead of a regular model. Vinyl floor (no carpet), basic seats, no insulation anywhere, no center console, basic vinyl rear seats. I took the full size spare tire and the ammo lock box out of the trunk.
It started out with about 18 mpg highway. Every little bit of maintenance helped. Sticking brakes were replaced, wheel bearings greased, fresh juices in the trans. I turned my stock airbox into a $300 "high performance open element intake " by removing the lower half so that the entire filter is out in the open. It looks stock until you go to change the filter and there is no bottom to the box, only the clips to hold the filter in. Not really a warm air intake, but these poor 4.6 engines are so strangled at the intake and plugged up in the exhaust that opening it up made a vast improvement. I also got a junkyard alternator from a '97 that was a tad smaller and had a larger pulley, almost like an underdrive one. I'm now up to around 23-25 highway.
Future plans include somehow sealing up the monstrous body panel gaps everywhere and either making my own under body panels or finding some from a pre-98 model or Grand Marquis. I think the earlier cars had extra panels to improve airflow that were removed in later years to reduce cost.
I rigged up a switch to shut the field off on the alternator and have played around with turning it on and off under certain conditions, but don't want to do much with a standard lead acid battery.
I would like to try and hit 28 mpg without drastic measures (ps delete, electric water pump).
Whew, I think that's the most extensive summary I've ever given for either vehicle. Cheers to FE on some "big" cars!
The Following 2 Users Say Thank You to mechcd For This Useful Post:
BabyDiesel (05-03-2015), MobilOne (05-03-2015)
