Old 05-04-2015, 12:14 PM   #35 (permalink)
P-hack
P-hack's Avatar
awesomer - '04 Toyota prius
hvdc is here to stay.
"A high-voltage, direct current (HVDC) electric power transmission system uses direct current for the bulk transmission of electrical power, in contrast with the more common alternating current (AC) systems.[1] For long-distance transmission, HVDC systems may be less expensive and suffer lower electrical losses. For underwater power cables, HVDC avoids the heavy currents required to charge and discharge the cable capacitance each cycle. For shorter distances, the higher cost of DC conversion equipment compared to an AC system may still be warranted, due to other benefits of direct current links."
The Following User Says Thank You to P-hack For This Useful Post:
NeilBlanchard (05-04-2015)
