The Accord's engine is more advanced. It has 13:1 compression vs 10.8:1. 16 valves vs. 8 valves. It's CARB rating is LEV3-SULEV30 vs ULEV2/AT-PZEV.
The electric motor in the Accord is rated at 166HP vs 23HP in the Civic. They don't list the battery size, but you can bet it's bigger in the Accord. That is a huge amount of additional work the electric motor can do that the gas engine doesn't have to.
The Civic torque rating is listed as 127 @ 1000-3500. The Accord on the other hand is listed as 122 @ 3500-6000 (thank you DOHC). The Civic is designed to rely more heavily on the gas engine than the Accord.
Final drive ratio is 3.42 in the Accord vs 3.94 in the Civic. That right there is highway mileage.
The two cars are just not designed with the same balance in mind. Perhaps the next refresh of the Civic will reflect increases commensurate with the 2015 accord.
