Old 05-05-2015, 06:05 PM   #20 (permalink)
aerohead
cheat
Originally Posted by BabyDiesel View Post
0.13 Cd?!?!?!? That is crazy talk!
I have thought about doing a second windshield similar to what basjoos did on his aerocivic. He said in another thread that while he didn't have exact numbers, it did help improve his coasting distance. With a car as light and as aerodynamic as his, I am guessing randomly that his Cd key have dropped close to 0.15.
What exactly do you mean by cheat the windshield?
I do plan on extending the front. I need to lower the stagnation point so air can flow over the Top, rather than under my car. I probably won't extend it to match the template... If I did, LOL
When Walter Lay did his wind tunnel research,he found that the drag of an 'ideal' form could be duplicated with an 'optimized' windshield.Both gave Cd 0.12
With respect to 'reversed' bodies,there is zero wind tunnel studies performed with 'mutilated' forebodies.So we don't have any knowledge about what happens if we disturb the contour of a reversed body to create a 'working' windshield.
If it turns out that we can't,without raising drag,then Hucho would say 'fuggetaboutit', 'cause,the distortion of the radically-raked windshield would be too great to see through.
This Citroen Karen would be impossible to see out of
BabyDiesel (05-06-2015)
