Old 05-05-2015, 10:03 PM   #2 (permalink)
user removed
Not sure how the evaporative emissions system could cause your refilling issue. Maybe try a block of wood under the rear tire nearest the fuel filler neck. Cars with fairly flat tanks under the rear seat and long fill tubes for the gas can really fight a fill up if your rear end is even slightly downhill.
regards
mech
