Old 05-06-2015, 07:05 AM   #4 (permalink)
pete c
yeah, a taller 5th would be nice. I think next time I get tires, I am going to look at going with something a tad taller. Cheap way of getting a higher final drive.
Does anyone know if the 5th gear can be swapped to anything taller as can be done with saturns?
Have you done a FI cutoff switch? That is something I want to do as well. As with many newer cars, turning the ignition to the ACC position kills the headlights. This is a bit un-nerving on dark state hiways. And likely a good way to get you pulled over by "the man".
