Old 01-10-2008, 05:32 AM   #41 (permalink)
newtonsfirstlaw
The Mighty Mira - '92 Daihatsu Mira
90 day: 61.32 mpg (US)
Originally Posted by Peter7307 View Post
The roads are flat and the cruise is on which recirculates some of the exhaust gas as well as holding the throttle steady.
There may be a lean burn factor cutting in under these conditions as well.
I think you are right. There is less load on the engine, but it is too close to idle and so uses more fuel! Pulse and glide at the slower speed is pretty much always more efficient though, but probably not something to try in an auto.
See this page here.
EGR is typically not employed at high loads because it would reduce peak power output, and it is not employed at idle (low-speed, zero load) because it would cause unstable combustion, resulting in rough idle.
"Every body perseveres in its state of being at rest or of moving uniformly straight forward, except insofar as it is compelled to change its state by force impressed." - Isaac Newton
