I didn't do the PI loop the traditional way. I did it like this:
Let P and I be the constants. error(t) is the error between the desired current, and the actual current. pwm(t) is the duty at time t.
pwm(t) = P*error(t) + I*INTEGRAL(error(TAU)), where the integral goes from 0 to t, hence the dummy variable TAU (remember that in calculus? hehe. They always use TAU! What's up with that?).
Differentiate both sides:
(2) d (pwm)/dt = P*d(error)/dt + I*error(t), by the Fundamental Theorem of Calculus. (The one where differentiating the integral leaves the function)
Now, I approximated d(error)/dt and d(pwm)/dt by finding the slope of two points for a small time interval, like 0.001, which was my throttle sampling rate back in the day, and substitute it into equation (2).
So, d(error)/dt IS REPLACED WITH (errorNew - errorOld)/deltaT. (remember the difference quotient. We just aren't letting h --> 0. Just using small h)
Also, d(pwm)/dt IS REPLACED WITH deltaPWM/deltaT.
Also, replace error(t) with errorOld. (You could use either errorOld or errorNew if you wanted I think).
So, after substituting, Equation (2) becomes:
(2b) deltaPWM/deltaT = P*(errorNew - errorOld)/deltaT + I*errorOld
Now, multiply both sides by deltaT:
(3) deltaPWM = P*(errorNew - errorOld) + I*deltaT*errorOld
Now, distribute P, and get all the errorOld stuff together:
(4) deltaPWM = P*errorNew - P*errorOld + I*deltaT*errorOld
(5) deltaPWM = P*errorNew + (I*deltaT - P)*errorOld
So, kp = P, and ki = I*deltaT - P. kp and ki are constants, because I, P, and deltaT are constant.
