Old 05-07-2015, 06:16 PM   #27 (permalink)
aerohead
are the
Originally Posted by mwilliamshs View Post
are the straighteners the horizontal surfaces (and the transition to such) at the rear of the skirts?
Yes.They intrude into the airstream and create a physical boundary which directs the flow and helps isolate it from hostile pressure gradient across the 'border' which might otherwise induce a span-wise flow,spinning up into power-robbing vortices.
Once the flow is aligned with the fence,it builds momentum which tends to keep it moving in that direction.
