Originally Posted by Goofy1
Wow, something I have a tiny bit of experience with!!...2. I blocked off the grill...
Originally Posted by Varn
I drive a 2005 Econoline and had a 1990 before that. One thing that has helped the economy is to put three layers of metal window screen behind the grill work....
My grill blocking^ (far right column is blocked) from here:
Big Van trashcan grille block
...Running the tires at max pressure helps.
^Not exactly original advice but valid all the same
