Originally Posted by Lovemy92vx
Can that be remedied?
Make sure the compression test is done with the throttle wide open and preferrably the plugs out of the other 3 cylinders. Cranks faster and gets full atmospheric pressure for the test.
If it's still that low you need the rings replaced and other work done depending on the condition of the cylinder walls.
regards
mech
