I was also thinking about a gas pedal. But if I let the engine run at idle, then there isn`t any gap. It runs ok and reacts smoothly to the pedal. It must have something to do with Deceleration Fuel Cut-Off when braking with engine.
I found one interesting post about this problem. I just cannot insert any links to this post, but I think ever green has a solution to this problem. Only his car is gasoline and automatic gearbox. Can make a difference... dunno.
Ever green says:
So I opened my ECU ROM in Romraider (a subaru open source flashing system) and found overrun fueling tables. I just raised overrun fuel injection rpm from 1100 to 4500 rpm and now my car doesn't enter fuel cutoff at all.
