Not much progress to report, but here goes:
- saved the hex file Paul loaded in while I was in Phoenix
- compiled and downloaded ACController code from instructable (thanx - P-hack!)
- precharge and main contactors click in sequence
- menu text is displayed (at 115,200 baud, not 38,400)
- config shows the default config
- run-pi-test does nothing, or at least appears to do nothing
40.5V DC between B- and B+ (3 x 12V lead-acid)
no current coming from the batteries
no resistance on the motor when you turn the shaft
.. tomorrow I try debug mode ...
