Old 05-12-2015, 11:36 PM   #33 (permalink)
oil pan 4
Originally Posted by sendler View Post
Does a lighter battery save fuel? What is the payback on the Lithium battery? Or thousands of dollars of rear end pieces?
I don't know what the pay back on the battery is. It was originally done for my suburban to delete the lead acid batteries up front to make room for a second turbocharger and to fit the largest off the shelf air filter I could find under the hood, after I built an air cleaner around it.
Then the Camaro needed a new battery and since the suburban lithium batteries are on quick disconnects. It wasn't a huge stretch of the imagination to fix that problem.
So the lithium battery mod really didn't cost anything and has already saved me cost of at least 1 battery.
Don't worry about the rear end, it will serve many functions beyond the what the GM 7.5 inch 10 bolt could ever dream of in addition to saving weight.
