Originally Posted by kir_kenix
when towing
Its getting a hitch.
Is it worth dropping hundreds or thousands of dollars into shaving a few pounds? Of course not, the payback might take a million miles. Is it worth swapping heavier parts in need of repair/replacement for lighter/stronger ones? Yes, pretty much every time.
The 7.5 inch 10 bolt has over 200,000 miles on it, they are difficult to rebuild and just as fun when it comes to gear ratio swaps and easy to screw up.
If the ring and pinion are put together and out several thousands of an inch after a rebuild or gear swap it will run fine for a few thousand miles then fail catastrophically with out warning.
Did I mention I was going to do some towing with it.
I could push and push and push ever closer to disaster, then when it breaks I will surely be at least a few hundred miles from home and wishing I got the 9 inch, because I will have just spent a good portion of what one would have cost on a tow job and replacing the broke down 10 bolt with a worn out one from some random junk yard.
