Old 05-14-2015, 01:05 PM   #5 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Any vacuum line after the throttle body will work fine.
I was always told that the closer you get to the manifold, the more accurate your readings will be? I suffered from this on my Camry back when I drove it. When I tapped close to the brake booster, it was way off, by 3 or 4. When I moved it to right up against the manifold, it was reading dead on.
