Old 05-14-2015, 03:23 PM   #12 (permalink)
mixu-
Jazz - '11 Honda Jazz Elegance
90 day: 44.64 mpg (US)
Honda Jazz air dam
I made my first air dam on my hybrid Jazz (european version of Fit) today. Jazz already has a small rubbery air dam to begin with. It's about 5cm tall and has 15cm (6") ground clearance.
I pushed my luck a little bit and made an extension of 5cm out of black coroplast. I used duct tape and zip ties to install the coroplast over the existing air dam. The job turned out to be really easy and fast. I drilled a hole through both the coroplast and the rubber and used two zip ties and two washers per hole to keep things in place.
I didn't get a chance to try it yet but it looks good for the first prototype and seems sturdy enough. Will post results soon.
The Following User Says Thank You to mixu- For This Useful Post:
Eddie25 (05-18-2015)
