I am looking for a used service truck or van. Consideration is roof ladder
I am what is called a Low voltage/Data com technician. I can go to a site, tear down the network, replace the 6.5 foot call rack 1 inches wide. Inside of truck can contain 2-3 boxes of network cable boxes and stock.
I have looked at used vans...every one in the 2000's is v6 and do not need that pulling power or less then desirable fuel economy. 4 cylinder would be fine. A truck has more options to create a canopy that can cuve to a wedge, if needed. Has anyone had more luck making a truck more fuel efficient then a van? I would like to some how put the six foot ladder in the truck. Make a cheap duel deck rack and slide ladder under neath deck and have stock and supplies on top of deck. Something lighter then plywood would work. Keep cost of van down so it would be a 2000 van or truck
