Old 05-15-2015, 12:53 PM   #2 (permalink)
bentring
Stream - '16 Volkswagen Jetta
90 day: 33.7 mpg (US)
I was in a similar situation as you when I signed up here. I happen to install acoustical drop ceilings so I'm quite familiar with you data cable installers.
Regarding your question, yes, it is possible to make a truck more economical than a van, but it depends on which truck and van we are discussing. I'd say with 99% certainty that you don't need a truck for your job.
Assuming you work solo and this is a work only vehicle, I would be looking at hatchbacks or the smaller station wagon type vehicles. With very little ingenuity, a 6 ft ladder and your stock (unless you keep a lot more on hand than they guys around here) will safely fit inside a whole lot of vehicles, where my scaffold was a bit more of a challenge.
If you have a helper at times or you just can't see fitting your stock inside a car/suv, move up to a minivan search and just remove the rear seats. You'll be better off economically than any full size truck.
The Following User Says Thank You to bentring For This Useful Post:
Daox (05-15-2015)
