Old 05-15-2015, 10:41 PM   #18 (permalink)
Chrysler kid
5 pin sensor
Zippy - '96 Honda Civic Hx
90 day: 40.77 mpg (US)
Boring - '11 Ford Fusion Sel
90 day: 21.88 mpg (US)
Ok let's start over again
How many miles do you have on:
Distributor cap
Ignition rotor
Spark plugs
Spark plug wires
Have you tried to use carb cleaner around the intake manifold and hoses to check to see if the rpms change when sprayed on a certain part?
Have you cleaned the idle air control valve lately?
Is the coolant still fresh ?
Do you have any oil leaks around the valve cover
When is the last time you changed the air filter and inspected the throttle body for any dirt or build up
There was a Toyota echo 5 speed idling super low that just had tons of gunk built up on the throttle body the other day.
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
The Following User Says Thank You to Chrysler kid For This Useful Post:
California98Civic (05-16-2015)
